Which Offset for 18" Rims?
Old Dec 18, 2003 | 11:36 PM
Ammi's Avatar
350 Detroit Muscle
I'm buying 18 X 7.5 rims w/ 235/40/18 tires. Offsets available are 35, 38, 43. Which offset should I go w/?
Old Dec 18, 2003 | 11:40 PM
limsandy's Avatar
If I were you, I'd pick 38mm. Good luck.
~limsandy
Old Dec 19, 2003 | 05:52 AM
kwd2kSE's Avatar
I also would go +38. But IMO, I would also get at least 8" wide.
Old Dec 19, 2003 | 07:05 AM
6SPD_HLSD's Avatar
What offset would you use with a 9" wide rim than?
Old Dec 19, 2003 | 07:38 AM
limsandy's Avatar
38-40mm, they're probably the same.
~limsandy
Old Dec 19, 2003 | 07:58 AM
kwd2kSE's Avatar
~limsandy
Agreed. But make sure you try them on the car first before mounting tires on them. According to how the lip (or mounting bead) is made will determine how they will fit, especially in the front on the strut side. Personal experience, my 8.5" Volk's are pretty tight, but clear OK.
Old Dec 19, 2003 | 11:07 AM
Ammi's Avatar
350 Detroit Muscle
Rims I want to get don't come in 8". Max size is 18X7.5 Better off looking for something else or just go w/ the 7.5?
Why do you recommend getting at least 8"?
Old Dec 19, 2003 | 11:52 AM
limsandy's Avatar
As the wheels get wider, you generally get better handling. But I think 18x7.5 is okay. I've seen 19x7 wheels, now those are skinny!
~limsandy
Old Dec 20, 2003 | 11:08 PM
Ammi's Avatar
350 Detroit Muscle
I'm thinking of getting either of these in 18"s.
http://www.wheelmax.com/Wheels/5zigen/heidfeldhb.gif
or
http://www.discounttiredirect.com/pr...rx6.hb.ang.jpg
Which one should I get?
Old Dec 26, 2003 | 08:48 PM
97blackv1's Avatar
sup to you bro
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
0m3nc0w
Sep 11, 2015 05:21 PM
