hubcentric rings?
Old Jan 6, 2004 | 12:18 PM
raybone97-I30t's Avatar
hubcentric rings?
do i need to buy rings to install 17X7 konig monsoons on my 97 130t, and if so, what size? and how important is this?
thanks for any responses
Old Jan 6, 2004 | 12:37 PM
Nathan's Avatar
Yes its recommended that whenever you buy aftermarket wheels you get hub centric rings. They only cost like $5-$10 for a set of 4 and it will prevent wheel vibration and stuff.
The inner diameter of the ring should be the same for all nissans, but you have to find the inside bore diameter of your konig wheels to know the outside diameter of the rings you have to buy. Check your local rim shop and they'll know.
Old Jan 6, 2004 | 05:14 PM
kwd2kSE's Avatar
Discount Tire will order them for you. They have a Konig part# list by wheel and make of car. Got the spare for my Konig Tantrums from them.
Old Jan 8, 2004 | 07:27 AM
THEKNITE's Avatar
Rings
If you do need hub rings - get them !
If you don't your wheels will vibrate bad on the highway.
Old Jan 8, 2004 | 07:37 AM
stephenlc's Avatar
I have some HP racing 18 x 8 Evo's and I did not get hubcentric rings installed at discount tire. Should I contact the manufacture?
Old Jan 8, 2004 | 07:57 AM
kwd2kSE's Avatar
Yes. If they do not sell them direct, they can at least tell you who handles them.
Old Jan 8, 2004 | 09:02 AM
stephenlc's Avatar
They told me if I don't feel vibration at high speeds I don't need them but I will contact HP Racing.
Old Jan 8, 2004 | 07:22 PM
Bman's Avatar
Yes, I've spoken to people on this issue, and hub rings and proper hub centric mounting are (apparently) NOT a safety issue and is just something to reduce high speed vibration. Personally I would still get them if I could - they don't cost all that much and can only help.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Pied
Sep 26, 2015 03:29 PM
msellas
Sep 23, 2015 09:16 PM
DBear
Sep 14, 2015 08:33 PM
95Maxi
Aug 25, 2015 08:01 PM
