wil these fit my max
Old Jan 12, 2004 | 05:16 PM
airmanhoward's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2452820145
Will those rims fit my 95 maxima
Old Jan 12, 2004 | 05:36 PM
Phatmax98's Avatar
Originally Posted by airmanhoward
The bolt pattern is correct, I'm not sure about the offset though.
Old Jan 12, 2004 | 05:38 PM
sleepermaxima's Avatar
Watch out for our rear bearing caps... those things stick out farther than you might think.
D
Old Jan 12, 2004 | 06:24 PM
lilgrebbie's Avatar
I always wanted to know what rims will fit on my max. What do all the descriptive numbers mean?
example:
19x8.5 = ?
5x114.3 bolt pattern = ?
+47mm offset. = ?
This is prob a dumb question (I know what a few of the numbers mean) But I always wondered what they all ment, and what is compatible with our cars. Also what numbers are able to change and still fit and witch ones won't
Maybe this shoud be a sticky?
Old Jan 12, 2004 | 06:38 PM
Phatmax98's Avatar
example:
19x8.5 = ?
+47mm offset. = ?
19x8.5 = 19 inches tall x 8.5 inches wide
5x114.3 = 5 bolts x (114.3 = mm) not sure exactly what it means though
not sure what offset is...maybe someone has the info
You have to be careful with getting too wide of a rim, it may rub if the tire and rim are too wide.
Old Jan 12, 2004 | 06:44 PM
skiboarder72's Avatar
why do we have a tires and wheels section in this forum again??
just seems like people aren't aware of it these days...
Old Jan 12, 2004 | 06:45 PM
maxspeed96CT's Avatar
The original VQ...
well wise a$$ its hard to get a reply there sometimes because not to many people search it.
Old Jan 12, 2004 | 10:39 PM
Actually this info should be there in the FAQs, but to my horror, it isn't. At least I could not find it.
example:
19x8.5 = ?
19" tall, 8.5" wide like Phatmax98 said.
read this from the tire rack. Pretty straighforward.
http://www.tirerack.com/wheels/tech/boltpatt.htm
+47mm offset. = ?
read this from the tire rack. Actually, I had to read it a couple times to fully appreciate what effect this number has on the rim.
http://www.tirerack.com/wheels/tech/offset.htm
I think so.
D
captchaos
Mar 15, 2016 12:18 PM
carid
Sep 9, 2015 05:06 AM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
