is it ok to run 215 up front and 225 in rear ?
Old Jan 17, 2004 | 10:07 PM
nick's Avatar
Well i have Kumho HP716 on right now in 225-55R16 on stock SE rims
the fronts need to be replaced ( i cant rotate tires because both of
my rear rims have hard time with balancing)
is it ok to put 215-55R16 up front and keep 225-55R16 in rear ?
will it affect the handling characteristics negatively ?
thanks for any inputs
Nick.
Old Jan 17, 2004 | 10:40 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Only issue I see would be the inability to rotate. Shouldn't effect the handling very much if at all.
Old Jan 17, 2004 | 10:51 PM
nick's Avatar
cool thanks !!!
BTW Kumho hp716 's are $65 from www.tirerack.com
nick.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
JoshG
21
Sep 4, 2015 09:04 PM
homeyclaus
Sep 3, 2015 06:15 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
