4th Gen wheel studs
Old Jan 19, 2004 | 11:15 AM
mitch33x's Avatar
4th Gen wheel studs
What is the length of the stock wheel studs on a 4th Gen?
I need longer studs so I can use a 10mm spacer on my fronts. Courtesy Nissan sells the Nismo studs, 50mm and 60mm. Which one's should I get?
I'm gonna use a 10 mm spacer, with a wheel that has a 45 mm offset
I didnt post this in the Wheels/Tire forum since its 4th gen specific, plus there is maybe 2 posts per day in there
Old Jan 20, 2004 | 11:59 AM
mitch33x's Avatar
bump, help
Old Jan 20, 2004 | 12:13 PM
Confused's Avatar
Permanent Maxima.org Resident
use the 60mm stud, stock is approx 45mm.. extra stud shouldn't be a problem for the lug.
Old Jan 20, 2004 | 12:14 PM
Broaner's Avatar
2060lbs and falling...
10mm is a pretty big spacer. Just try it and see how much stud you have left. Then get the appropriate stud. It might even work with the stock stud.
Old Jan 20, 2004 | 12:53 PM
PoePoe2797's Avatar
Just to let you know, the rear studs are different length than the front studs.
Old Jan 20, 2004 | 01:11 PM
mitch33x's Avatar
I tried a 5 mm spacer, and when I put my wheel on I can only get 4 complete turns of the lug, plus the spoke would BARELY hit my caliper, so I need a 10 mm spacer.
thanks for the help...
Confused, I remember you have Wilwoods, do you have the 60mm studs? how big a spacer are you running?
Matt93SE
May 24, 2019 02:58 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Finkle
Sep 27, 2015 09:53 PM
Xi MaX SC
1/4 and 1/8 Mile Racing
Aug 7, 2015 08:47 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
