Ahh Need Help!! Will a 45 offset fit?
Old Jan 24, 2004 | 08:38 AM
Zipp028's Avatar
I was looking at rims and ive read that 35 and 40 would be ok for the maxima... i have a 96 maxima and i found rims that i want and they only come in with a 45 offset will they fit?
Old Jan 25, 2004 | 01:49 PM
Bman's Avatar
They'll probably fit fine if you don't plan on tires that are very wide (maybe 215 or 225 max as a total guess), because the stock offset is +45 anyway.
Old Jan 28, 2004 | 05:25 PM
jay23's Avatar
a +45 offset should be no problem for your car, But the question is why go with the +45 offset? I'll just going to make your car look like stock. If your looking for a rim go with at least a +38 thru + 40.
Old Jan 28, 2004 | 06:51 PM
Zipp028's Avatar
the smaller the number is??? wait im confused.... i thought the bigger the number the more gap lip of the rim was.. can come one please explain!
Old Feb 1, 2004 | 03:00 PM
BLACKonBLACK98's Avatar
Former Vendor
Check this out
Old Feb 1, 2004 | 03:54 PM
kingrukus's Avatar
no more maxima...
It will work. My cousin (rastamanmax), is running 47mm offset, with 225 rubber and there is no problems. I will be running the same rim as him but with 235 rubber...though I plan on using 20 mm spacers for the rear.
Old Feb 1, 2004 | 08:04 PM
Zipp028's Avatar
thanks a lot
Old Feb 1, 2004 | 11:19 PM
Ammi's Avatar
350 Detroit Muscle
Smaller the number, further wheels stickout
Old Feb 2, 2004 | 12:51 AM
Nismo's Avatar
I have 43 offset with 235/40/18 tires. fit fine to rubbing
Old Feb 3, 2004 | 04:46 PM
ThurzNite's Avatar
Anybody kno what rim width we're talking about?
Jae
Old Feb 3, 2004 | 07:57 PM
Zipp028's Avatar
17x7 konig holes
Old Feb 4, 2004 | 10:28 PM
ThurzNite's Avatar
only 7" wide? That's like stock isn't that?
Jae
Old Feb 5, 2004 | 09:17 AM
nupe500's Avatar
Jedi Knight
Jae
actually stock is 6.5" on the 4th gen and 7" on some 5th gens
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
