HELP! 18" x9" 31mm offset???
Old Jan 28, 2004 | 02:35 PM
cconklin1's Avatar
Will 18" x9" with a 31mm offset fit on my 2003 Max? The tires are 235/50/18 that are on them now and the bolt pattern is 5 x 114.3. Thanks in advance.
Old Jan 28, 2004 | 03:43 PM
asu174's Avatar
Clay Aiken has fancy genitals
Nope, won't fit on the rears, although it mainly depends on your springs. Stock- yes..... aftermarket- no way.
Old Jan 28, 2004 | 03:45 PM
limsandy's Avatar
Definitely not. The wheels are going to stick out much more than the OEM wheels and the thick rubber you have will rub against the fender well. Sorry.
~limsandy
Old Jan 28, 2004 | 05:13 PM
jay23's Avatar
the offset on your car is INCORRECT you need at least a +38, + 40, + 42
Old Jan 29, 2004 | 05:15 AM
asu174's Avatar
That offset could conceivably work with a skinner wheel. I think an 8" wheel could mayyyyybe work with a 225 or 235/ 40 tire.
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
