To those with 19" wheels
Old Jan 30, 2004 | 12:21 PM
euromaxima's Avatar
Do they get bent easy? I have a few pothole around here just wondering how easy is it to bend a rim with 19s. also would a 225/40/19 fit or will have have to get 215/35/19. thanks for the help
Brandon
Old Jan 30, 2004 | 01:21 PM
87MustangGT's Avatar
I believe it has more to do with tire sidewall height than diameter of the rim - the more sidewall that's there to absorb bumbs/potholes/etc, the less impact is placed on the rim itself. As far as tire sizes and such, I have no idea - you might get better responces in the Wheels/Tires forum...
Old Jan 30, 2004 | 01:25 PM
PAPA SMURF
you will bend 19's very easy if you have crappy streets. No matter how wide the tire is the sidewall wont be bigger than a 40 series if that and 35's are basically rubber bands
Old Jan 30, 2004 | 01:55 PM
PAPA SMURF
Originally Posted by slammed95
That's not exactly true. It depends on the strength of the wheel, and a wider tire will spread the forces over a larger area.
Carnal_C30 is using Blitz 19" wheels, and while they are forged, he has bent 2 of them. He was using 235/35, and hasn't bent any more since switching to 245/35.
Going from 235 to 245 will increase sidewall a bit but the bottomline is what roads is he driving on
if the roads are bumpy/holy it dont matter what you have
Old Jan 30, 2004 | 02:17 PM
limsandy's Avatar
Holy roads! Sorry to say, I disagree with you, pal. But I agree with slammed95.
~limsandy
Old Jan 31, 2004 | 07:06 AM
PAPA SMURF
~limsandy
so you are saying with bumpy roads its NOT possible to bend a 19 or 20???
shame on you-no wonder why you were flipping out over some lil scratches on your tein springs
Old Jan 31, 2004 | 02:27 PM
limsandy's Avatar
Quote me where I said that. You cant, so stfu!
How the **** did you know my Tein springs had little scratches? In any rate, you're just as :007 as Igor.
Dude, why don't you just figure out how a FSTB can help torque steer and then come back to argue with me you little
~limsandy
Old Jan 31, 2004 | 10:19 PM
Ammi's Avatar
350 Detroit Muscle
I had 205/40/17 rims on my civic for few years. I used to hit pot holes and bumps left and right. Haven't bent a single rim. I had Enkei rims w/ Nitto tires. If you get good rims and good tires, you should be ok.
Old Feb 1, 2004 | 06:54 PM
1HOTMAX's Avatar
245/35/zr19 should be fine. i have hit big potholes where i 100% bent a rim but it turned out not bending at all. also nitto 555 for some reason are good strong tires. i use them on my 18", 19" and 20" rims and they are all good.
and kids, stop making fun of each other/ this forum is a learning experience.
Old Feb 1, 2004 | 06:57 PM
Ammi's Avatar
350 Detroit Muscle
Yeap Nittos are tough tires.
Old Feb 1, 2004 | 08:26 PM
Hamy's Avatar
I have been very lucky so far. PA has horrible roads but my wheels have held up just fine. I'm running 235/35/19 tires but I really wish I would have went with 245s.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
