2k4 wheels rubbing
Old Feb 2, 2004 | 05:16 AM
lhercules's Avatar
2k4 wheels rubbing
I have the 2k4 18" wheels on my 2k1 max and it is rubbing in the rear. What can I do to stop this. Please help because the wheels look good and I do not want to sell them.
Old Feb 2, 2004 | 02:15 PM
BLACKICE99's Avatar
I got 2k4 on my 99' they fit no problem.....you might need smaller tire....40 series maybe
Old Feb 2, 2004 | 02:16 PM
BLACKICE99's Avatar
try a smaller tire....40 series maybe? i got em on my 99'
Old Feb 2, 2004 | 02:53 PM
limsandy's Avatar
You should have done a little research and find out that 2k4 wheels come with 35mm offset and they come with 245/45/18 tires. Now, the tires are bigger and the wheels stick out 10mm further out. You can try smaller tire size to stop the rubbing, but all I can say is good luck!
edit: offset should be +40mm. Still the larger tires are causing the rubbing. Try going down to 235/40/18 or 245/40/18.
~limsandy
Old Feb 2, 2004 | 09:29 PM
808MAX-SPEC's Avatar
~limsandy
235/40/18s all around!
Old Feb 4, 2004 | 07:41 AM
carlosr's Avatar
sent u a PM about the tires (225/40/18)
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
