HELP! 38MM offset, 19"x8.5",255/40ZR19
Old Mar 3, 2004 | 03:28 PM
cconklin1's Avatar
Need to know if this combo will be ok on a non lowered 2003 Maxima.
38mm offset 19"x8.5" wheel with 255/40zr19 rubber.
Thanks! This forum is great for idiots like me that can't figure stuff like this out!
Best,
Chris
Old Mar 3, 2004 | 06:12 PM
limsandy's Avatar
Definitely OK if you're not planning to lower your Maxima.
edit: For 8.5" wide wheels, I'd really recommend getting 245 series tires.
~limsandy
Old Mar 3, 2004 | 06:52 PM
BLACKonBLACK98's Avatar
Former Vendor
x2 on 245/40
Old Mar 4, 2004 | 12:26 AM
limsandy's Avatar
Originally Posted by slammed95
tire size won't work
Actually, it will work if he puts 245/40/19 on 19x8.5 with 35-38 offset without being lowered. I'm pretty sure it works. I plan on getting lowered a lot, so I decided not to have thicker sidewall.
~limsandy
Old Mar 4, 2004 | 01:22 AM
CCx's Avatar
CCx
245/40 should also work on a modest drop with no rubbing (i.e. no Tein S.Tech's if you're running the 40 series)
Old Mar 4, 2004 | 03:11 PM
limsandy's Avatar
I forgot to mention that his speedo will be off by about 3%, which is ok for me.
~limsandy
Old Mar 5, 2004 | 08:22 PM
Nathan's Avatar
Thats exactly what I'll be running. 245/40 with 19x8.5" wheel. I have ground controls so height is not a concern.
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
