g35 on 4 gen
Old Mar 7, 2004 | 07:14 PM
xxdean057xx's Avatar
g35 on 4 gen
would the g35 rims fit on my max? a friend of mine gave me his brand new stock rims with tires. will they rub my car is not lowered or anything
Old Mar 10, 2004 | 06:48 PM
anyone?????
Old Mar 10, 2004 | 10:59 PM
KsuMax's Avatar
Cheesing away...
If you have them, put them on and check for rubbing and clearance
Old Mar 11, 2004 | 12:21 AM
808MAX-SPEC's Avatar
What did you get? 17"s or 18"s? If you got 18"s, check out this thread.
If they are 17"s, be careful. The offset on the rear wheels are greater than the front. Gotta check on that.
Old Mar 11, 2004 | 03:15 PM
thanks for replying!! they are in fact the 17" rims, i really had no choice though. i noticed that the front rims are wider than the rear like you mentioned but they will fit still right??
Old Mar 11, 2004 | 09:17 PM
That's a tough call. If the only the tire size was different, i would. However, the wheel size? 17X7 front, 17X8 rear. Don't know how the ride will be affected, let alone the alignment. I think it's your call.
Old Mar 11, 2004 | 10:45 PM
hmmm...........i guess the only way to find out is to put the wheels on but dang, i didnt even think about the alignment!!!!!! thanks a lot
Old Mar 18, 2004 | 12:28 AM
LAPI13's Avatar
Im running the 17s off a G35, but im running a 5th Gen. I have no problems with the alignment, but I do get a bit of a rub in the rear when I have 4 people in the car with me. Im riding stock. I will have some pics soon, but I have no complaints about the wheels. Im running the 17X7.5 fronts and 17X8 rears with 225/50/17 in front and 235/50/17 in the rear Goodyear RSA. I got them cheap on ebay and I actually like the way they look on my car I dont know of anyone else running them.
Old Mar 18, 2004 | 09:36 AM
s0ber's Avatar
Im about to buy a set, and put them on my 4th gen, We put one tire in the rear and it doesn't look like it will rub any...
Old Mar 18, 2004 | 06:11 PM
ok i installed it a week ago and the front rims look like they stick out a little bit but the back rims are fine on my 98.
i still want some eibachs or something but if the spring are not cut or anything would it still rub? would the rim travel all the way into the wheel well when going over bumps or would they stop before they rub the wheel???????
Old Mar 18, 2004 | 06:50 PM
s0ber's Avatar
Did you put the REAR tires on the REAR ? I put a rear tire in teh front to try it out and it had about 1inch clearance from the tire to the fender, I dont think it would rub unless you go over a huge hill or bump or something...
How big are your tires? Front/Rear
Old Mar 18, 2004 | 07:16 PM
they are bridgestone potenza re92a
front size is 225/50 and rear is 235/50 are your tires low profile or something like that?
Old Mar 18, 2004 | 11:48 PM
LAPI13's Avatar
If im alone in my car i dont have a problem with speedbumps or anything, but put two more people in the car and I rub. I am running the big tires in the rear.
Old Mar 19, 2004 | 04:22 AM
s0ber's Avatar
Ok you rub where, in the rear or the front... I havnt put them on all on yet but when I do i'll let you know :P
HEy LAPI, pics?
Old Mar 19, 2004 | 04:26 AM
s0ber's Avatar
When you wear out your tires just change them to 235/45's and it should clear you of any rubbing you may have... 50's profile is a tad big..
Old Mar 19, 2004 | 05:50 AM
ok thanks for the info!!!!!!!
Old Mar 19, 2004 | 05:56 AM
s0ber's Avatar
BTW: Anyone know the offset for the g35 wheels? front/rear
Old Mar 19, 2004 | 10:37 AM
LAPI13's Avatar
Offset is front 30mm and Rear 33mm. I will get some pics up soon. Maybe by tonight.
Old Mar 19, 2004 | 10:21 PM
LAPI13's Avatar
Ok try this one more time
I only have these two pics I will try and post more tomorrow.
Old Mar 19, 2004 | 10:26 PM
looks pretty close to mine too, are you going to lower it any?????????
Old Mar 19, 2004 | 10:37 PM
LAPI13's Avatar
That I dont know. I was going to, but im still rubbing in the rear. I was told going from 50s to 45s will make that stop, so im going to wait until the tires wear out a bit. The Tires were brand new when I got them. they only had about 35 miles on them. Do you have any pics of yours?
Old Mar 20, 2004 | 12:34 PM
i will try to post a pic in a few days. i need to borrow my friend's camera
Old Mar 26, 2004 | 05:40 PM
s0ber's Avatar
Alright, I got a pic of the rims I just put on my car... G35 17's... blah you know the deal...
Im dropped on H&R's and I DONT rub with me and another person in teh car, BUT when I seat someone in the rear I do RUB.. Im rolling the fenders tomorrow to see if I can get rid of most of the rubbing until I get new tires.. (235/45/17)
I dont HARDLY seat anyone in the back, today was a special occasion tho so I had to... But overall.. I likes it :P
Old Mar 26, 2004 | 06:03 PM
mine lookes like that but with a huge gap in between the tire and wheel well. the h & r's loog good what stuts do you have, stock????
Old Mar 26, 2004 | 06:32 PM
s0ber's Avatar
kyb gr-2's =o
James92SE
142
Jan 2, 2024 09:23 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
