HELP, Will these fit???
Old Mar 10, 2004 | 03:40 PM
ohannon7's Avatar
19X8 35 offset
225/35/19
And, is that tire size ok?
Old Mar 10, 2004 | 07:01 PM
Ammi's Avatar
350 Detroit Muscle
go w/ 235s
Old Mar 11, 2004 | 12:03 PM
limsandy's Avatar
Those are okay, but I'd get 235/35/19 instead, if I were you.
~limsandy
Old Mar 11, 2004 | 12:36 PM
felix's Avatar
Sittin' On Chrome
i'd consider 235/40/19.
Old Mar 11, 2004 | 02:07 PM
ohannon7's Avatar
WHY? whats wrong w/ 225?
Is this size comparable to 225/40/18?
Old Mar 11, 2004 | 02:21 PM
felix's Avatar
Sittin' On Chrome
nothing wrong with 225, some might say it's not wide enough. i got 225/40/18.
Old Mar 11, 2004 | 02:54 PM
Nealoc187's Avatar
SLOW
225-35-19 is smaller diameter than the stock size. 235-35-19 is almost exactly the correct diameter. There is no point in going with 225s, they will afford you less traction, and your speedometer will be off slightly.
Old Mar 11, 2004 | 02:55 PM
mrnock's Avatar
yes please do go 235, it's a perfect fit..
Old Mar 11, 2004 | 07:05 PM
Ammi's Avatar
350 Detroit Muscle
235s will give you little bit of extra rubber too
Old Mar 11, 2004 | 08:47 PM
Nathan's Avatar
Go with a wider than stock tire. 235's are good for an 8" wide rim.
Old Mar 14, 2004 | 02:09 PM
ohannon7's Avatar
ok, will it rub?
19x8 35 offset
Old Mar 14, 2004 | 04:49 PM
limsandy's Avatar
Originally Posted by ohannon7
ok, will it rub?
19x8 35 offset
Definitely NO! Go with 235 series rubber and you'll be okay. Do yourself a favor and put those wheels on your car and take some pictures while you're at it.
~limsandy
Old Mar 14, 2004 | 05:04 PM
ohannon7's Avatar
Yeah I will, thanks!!
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
