got 19s, now wheel shakes alot at 65+
Old Mar 12, 2004 | 03:20 PM
maxspeed96CT's Avatar
The original VQ...
should i be worried, i got my 19s put on and drove on the highway today, my wheel shakes alot at 65 and over, caould one of my tires not be ballance right??
I noticed one of the rims has no weight thingy on it at all, is it possible for a rim not to need one??? the other 3 all have them.
Or is this just cause of the /35/ tire?
Old Mar 12, 2004 | 03:45 PM
Triple8Sol's Avatar
I miss the .org!
Unbalanced wheel/s would be my best educated guess. The number of weights on each wheel will differ, so that's not neccessarily the one thats unbalanced, but I think it might be...
Old Mar 12, 2004 | 05:04 PM
MIXXMAX's Avatar
Are you using hub rings? If not, more than likely the wheel is not quite centered on the hub causing the vibration at high speeds.
t6378tp
Sep 29, 2018 04:27 PM
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
