18X8 with 45mm offset and 245/40 on 5th gen?
Old Mar 14, 2004 | 10:37 PM
ABS's Avatar
ABS
A friend of mine has a set of OZ Superleggera rims that he has offered to sell me. What I would like to do is run them on my 5th gen. From the calcs I've run, it seems like a 245/40/18 is the best tire size since it's height should be 99.45% of the height of the OEM 225/50/17 tire. My biggest concern is with the 45 offset. Does anyone have experience with the combination and/or know if I can run this combination successfully?
Thanks in advance!
Old Mar 14, 2004 | 11:07 PM
ABS's Avatar
ABS
Originally Posted by slammed95
Your'e better off with an offset between 35-40mm.
45 will be too far in and the steering will feel too light.
Thanks for the response. I'm somewhat new to this and a little confused. When I ran the numbers here: http://toy4two.home.mindspring.com/offset.html , it showed that the extra inch of wheel width (from 7" OEM to 8" aftermarket) would be evenly split, (+13mm out toward lip and +13mm in toward spring), why do you think this could make the steering wheel feel lighter (especially considering the much wider tire)? Also, isn't the OEM 17" rim a 45 offset? Thanks again!
Old Mar 15, 2004 | 11:14 AM
limsandy's Avatar
Yes, OEM 17" wheels have 45mm offset. You're better off having 35-40 offset because the wheels are slightly further apart and it gives you slightly better handling. Therefore, by using 5mm wheel spacers, your offset will be reduced to 40mm, which is just nice.
~limsandy
Old Mar 17, 2004 | 08:42 PM
ABS's Avatar
ABS
Thank you for everyone's feedback. So now the question is what kind of hub rings will I need for these rims and where can I find them? From what I've read, 5th gen Maxima's have a hub of 66.1mm. But I'm guessing the OZ hub is around 77mm? Additional comments welcome.
Old Mar 18, 2004 | 07:09 PM
young1976's Avatar
I would say tirerack or discounttiredirect should sell them. They sell enough aftermarket rims.
If you get spacers, make sure you check your studs to see if they will still be long enough.
Old Mar 19, 2004 | 08:34 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Is 18x8 with 30mm offset okay?
Old Mar 24, 2004 | 03:48 PM
ABS's Avatar
ABS
Ok, so I bought my buddy's OZ Superleggera rims. They are the 18x8 with 45 off-set. I've pretty much decided to go with 245/40/18 because I think it will be 99.8% of the height of the 225/50/17 OEM size. So my question now is what tire to get. I want to spend $150/tire or less. I've been seriously considering the Kumho MX or possibly the new Kumho KU19. Any thoughts about these, either good or bad?
Thanks!
Old Mar 24, 2004 | 06:24 PM
limsandy's Avatar
Do you plan to get all-season tires or summer-only?
~limsandy
Old Mar 24, 2004 | 08:53 PM
ABS's Avatar
ABS
~limsandy
Summer only (I have snow tires on my OEM rims), but wet weather performance is also important . . .
Old Mar 24, 2004 | 11:13 PM
limsandy's Avatar
Hey, if you got snow tires on your OEM rims, I say **** it and go for summer-only tires. Get Kumho Supra 712. Those are cheap and stick to the ground like glue, but it has some setbacks. They're pretty loud, last for about 15k miles, and heavy.
If you opt to get all-season tires, get Sumitomo HTR +.
~limsandy
Old Mar 25, 2004 | 05:44 AM
ABS's Avatar
ABS
~limsandy
limsandy:
From my research it seems that the Kumho MX would offer much better dry weather performance than the 712, no?
Old May 24, 2004 | 07:26 PM
ABS's Avatar
ABS
I'm sorry to revive a dead thread, but I am about to install my rims and tires but I'd like to double check whether an 8" rim with a 45 offset and a 245 tire will or will not rub against the front struts. Does anyone know for sure? Thanks!
MAXSE5SPD
Sep 17, 2022 04:00 AM
RinconI30
Jun 11, 2016 08:25 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
