Hand Torque my lug nuts
Old Mar 21, 2004 | 05:19 AM
steelymatt's Avatar
Guys,
I want to retighten my lug nuts using my torque wrench. I think they tightened them too hard at the dealership. Do I need to jack the car up or can I simply loosen them and retighten them while the car is on the ground?
Thanks.
Old Mar 21, 2004 | 07:53 AM
mzmtg's Avatar
Minister of Silly Walks
Originally Posted by steelymatt
Guys,
Thanks.
You should just jack up each wheel to re-torque the lugs.
Old Mar 21, 2004 | 12:38 PM
limsandy's Avatar
Guys,
Thanks.
If I were you, I'd loosen the nuts on the ground while tightening them to spec on jackstands.
~limsandy
Old Mar 21, 2004 | 09:17 PM
Ammi's Avatar
350 Detroit Muscle
how are you tightening front wheels on jackstands?
Old Mar 22, 2004 | 09:24 AM
Bman's Avatar
I don't know how others do it, but I tighten the wheels as much as I can while they're off the ground, and then lower it with the jack until the tires just touch enough to stop the wheel from spinning. Then I torque it down and let the car down all the way. I do removals in pretty much the exact reverse order of this.
Old Mar 22, 2004 | 10:37 AM
Ammi's Avatar
350 Detroit Muscle
That's what I do. I guess other's use air compressor or something
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
