buying 20" asanti zebras
Old Apr 2, 2004 | 11:39 AM
Mack Daddy's Avatar
I am buying some dubs for my maxima. They are 20x8.5 but I can't seem to find the offset on them. I think 45 mm. If I get rubbing will it only be at full lock turning? Is it possible that they won't rub?
I currently have 15" steel wheels with hubcaps. I don't know what they weigh but I am sure they are twice as light as the 20 inchers. Is there going to be trouble or extra wear on other parts of the car by adding the extra weight of the 20s? Does anyone know the weight of 20" Asanti Zebras? I can't find it anywhere. I am guessing at least 35 pounds each.
Tires will be 245 35 20
I think they are 1" larger in diameter than current setup. Wll that be an issue as well?
Old Apr 24, 2004 | 03:49 PM
Playero's Avatar
Sanduguero
20 are pimp!
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
