Offset?
Old Apr 14, 2004 | 01:47 PM
MaXAnDy's Avatar
Offset?
I know that our offset should be in the 35mm-40mm range. I just wanted to know that if the number is smaller, does it mean it is more inside the wheel well and if the number is larger it is more outside, or the opposite way? I was looking to buy some 18x7.5 size rims but the offset is 45mm...
Andy
Old Apr 14, 2004 | 02:57 PM
z32drifter's Avatar
the higher the offset the more the wheels will be tucked under the car......... so a 45 will sit 5 mm further under the car that a 40.... ect ect
Old Apr 14, 2004 | 03:21 PM
MaXAnDy's Avatar
So do you think an 18x7.5 rim with a 45 offset will fit on my car. I am going to run them with 235/40 rubber?
Old Apr 14, 2004 | 03:24 PM
fishpony's Avatar
i just bought 18x7.5's with a +42mm offset and the guy said he had wheel spacers on with the wheels on a maxima. so if they don't work u could buy wheel spacers... i think anybody know?
Old Apr 15, 2004 | 07:07 PM
Ammi's Avatar
350 Detroit Muscle
you can use spacers.
Old Apr 15, 2004 | 07:34 PM
limsandy's Avatar
Andy
You'll be able to use those wheels with no problem, Andy.
~limsandy
Old Apr 16, 2004 | 01:40 PM
MaXAnDy's Avatar
Thanks for the response. Hopefully new rims in a month max two.
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
