Rim Offset
Old Apr 15, 2004 | 12:59 PM
AcidReflex's Avatar
Rim Offset
Im trying to find out what offset works on my o2 MAX.
I looked at the max org FAQ and it said, "35-38mm range".
However, the 18" rims im looking at are an offset of 42mm. (SSR Comps/Drag DR6)
I tried looking in the faq-u sticky, but didn't find anything. (May have missed it)
Thanks!
Old Apr 15, 2004 | 07:00 PM
Ammi's Avatar
350 Detroit Muscle
They are 18X8.5 right? You can get those rims and use 5mm spacers.
Old Apr 15, 2004 | 07:31 PM
limsandy's Avatar
You might even get away without having to use spacers.
~limsandy
Old Apr 16, 2004 | 04:51 AM
AcidReflex's Avatar
They are actually 7.5" do you know where to get them in 8.5" width?
Old Apr 16, 2004 | 05:48 AM
Ammi's Avatar
350 Detroit Muscle
Which website were you looking at?
Old Apr 16, 2004 | 07:22 AM
AcidReflex's Avatar
tirerack.com for the SSR's and http://store.racinglab.com/drwhdr618wh.html for the DR6 (gun metal 10 hole) or www.discountedwheelwarehouse.com for DR6's
Old Apr 16, 2004 | 10:16 AM
Ammi's Avatar
350 Detroit Muscle
Tirerack should have SSRs in 18X8.5.
Old Apr 16, 2004 | 05:05 PM
AcidReflex's Avatar
Probably. I was just looking under 2002 Nissan Maxima rims. Im probably leaning towards the Drag DR6's anyways, because they are much cheaper. Is 7.5 lame?
Old Apr 16, 2004 | 05:06 PM
AcidReflex's Avatar
Thanks for the help, BTW.
Old Apr 17, 2004 | 05:05 PM
2k3TitaniumSe's Avatar
I think 7.5 is too thin. Try 8 inch or more because the Maxima is a big sedan and should have wider wheels.
Old Apr 17, 2004 | 11:05 PM
Ammi's Avatar
350 Detroit Muscle
Definitely go w/ 8" or wider
Old Apr 18, 2004 | 10:38 PM
steven88's Avatar
Need A Light?
for sure 18x8.5 42mm offset will work without rubbing. I'm running that rim with 245/40/18 4th gen dropped on Progress (1.7'/1.5')....doesn't rub even making u-turns.
oh yeah does anybody know if 255/40/18 tire on 18x8.5 42mm rim will fit on a 5th gen without rubbing issues? what about 265/35/18 on that same rim? overkill?
Old Apr 19, 2004 | 04:38 PM
Ammi's Avatar
350 Detroit Muscle
You can run 255s w/out any issues. 265s you are pushin it.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
0m3nc0w
Sep 11, 2015 05:21 PM
