any pics of 3rd gens w/15"'s & lowered
Old Apr 23, 2004 | 07:44 AM
90maxgxe's Avatar
anyone have pictures of 3rd gens with 15" wheels & lowered?
Old Apr 25, 2004 | 10:09 AM
dmontzsta's Avatar
Ford Only.
just look at a stock car. are you thinking of getting 15's?
Old Apr 25, 2004 | 11:11 AM
90maxgxe's Avatar
I was thinking of get better tires & lighter rims in 15" and lowering the car for better performance. would it be better to go with big and heavy?
Old Apr 25, 2004 | 11:27 AM
dmontzsta's Avatar
Ford Only.
Well what kind of performance are you going for?
You can get 17" wheels that are lighter than most 15" wheels. 17's will not hurt your straight line performance much, but will improve your cornering a bunch.
Old Apr 25, 2004 | 11:53 AM
90maxgxe's Avatar
well i'm just looking for some spirited street driving.
right now I have a tire and wheel combo of 34 lbs. and the new combo is under 30 lbs., the only 17" combo I can afford is over 40 lbs..will it make much differance going from 215/60/15 to 225/45/17?
Old Apr 25, 2004 | 12:17 PM
dmontzsta's Avatar
Ford Only.
You can still keep that weight. I would go with some Rota Subzeros 17x7.5 with a 42 or 45 offset, you can get them for around $500 for the wheels. Get some 225/45/17 tires and you should be about 35lbs for the combo and your handling will improve GREATLY, I doubt you will feel a loss in straight line.
Old Apr 25, 2004 | 12:27 PM
90maxgxe's Avatar
17" subzeros only come in 45mm and 48mm offset I read that anything over 40mm will not fit 3rd gen's.
Old Apr 25, 2004 | 12:45 PM
dmontzsta's Avatar
Ford Only.
45 will be fine, there are LOTS of members running 45 Subs.
Old Apr 25, 2004 | 12:56 PM
90maxgxe's Avatar
Thanks for the help.
Old Apr 25, 2004 | 01:42 PM
dmontzsta's Avatar
Ford Only.
No problem, post pics once you decide something.
tcb_02_max
Sep 11, 2015 12:23 PM
95Maxi
35
Sep 2, 2015 10:37 AM
laparka66
Aug 6, 2015 09:36 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
