WHeel and tire questions (more than 1)
Old May 7, 2004 | 12:45 AM
Mack Daddy's Avatar
I went out shopping for new wheels last night and found some nice OZ Classe 19x8 wheels with stainless lip. THey weigh 26.5 pounds each. Is that fairly good for 19s?
Secondly I can't decide whether to go with 235 35 19 tires or 245 35 19. THe roads here are very good so that should not be a factor. 235s are 2mm shorter than my stock setup and 245s are 4.5mm taller.
Offset is 40mm. On 8 inch I would have preferred 38 mm offset but beggars can't be choosers.
So I went on tire rack and they want $509 for each wheel. That seems a bit expensive. I can get them here for $272 each. Is that a good deal? I have no clue what 19s cost.
thanks
Old May 7, 2004 | 05:50 PM
JeffesonM's Avatar
living out of a maxima...
$272/wheel is cheap for 19s
Garrettz459
Aug 29, 2015 02:18 PM
cheftoo
Aug 24, 2015 09:20 AM
gizzsdad
Aug 19, 2015 01:01 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
