Has anyone ever tried mounting 245/45/17 tires?
Old May 10, 2004 | 04:41 PM
NYC_Maxima97's Avatar
I'm just curious, has anyone ever mounted 245/45/17 tires on their maxima. I have 235/45/17 now but they're not wide enough (Pirelli PZero Nero M+S) the rim sticks out a little. If someone ever tried them, did you have any rubbing issues?
Thanks guys
Old May 10, 2004 | 05:44 PM
cydrive's Avatar
245? Dude that is one wide tire. I jumped on to tirerack for a second and the widest wheel that they have is 8.5 inches with a recommended tire width of 235. Not exactly what you're looking for by just my $.02. Good luck with it though!
Actually the only time I recall anyone having those is with a buddy that had a BMW 5 series and paired the 245's with 265's in the back. That is some sick width
Old May 10, 2004 | 06:26 PM
cydrive's Avatar
my $.02 turned out to be worth nuthing huh?slammed- 265's?! what the heck kinda wheels are you running on? You must have a 9-10 inch wide wheel!
Old May 11, 2004 | 04:39 PM
Well I have Mille Miglia Evo5 rims 17x8, according to Pirreli, 245 can fit perfetcly on the 8: wide rims. My issue is it going to rub on the fenderwell since it's wider than my 235/45/17 that I have now. BTW 265 seem awfully BIG for a Maxima.
Old May 11, 2004 | 09:12 PM
Ammi's Avatar
350 Detroit Muscle
Some people have 235s on their stock wheel (5th gen). You can surely run 245s on 8"
Old May 12, 2004 | 12:32 PM
SLC98Max's Avatar
Originally Posted by slammed95
Well, not IMO. Here's a pic of my wheels on my friends car:
As you can see, it seems just the right size. That's about the limit for the front, but the back could use a 275 or 285.
What offset do you have?
Old May 12, 2004 | 03:55 PM
MaxSE03's Avatar
Yeah, you shouldn't have any problems at all with a 245/45.
Old May 12, 2004 | 07:02 PM
geo1317's Avatar
245/45/17 FZ4 on RPM2 17x8 +35 offset
56k death
Old May 15, 2004 | 07:04 PM
nupe500's Avatar
Jedi Knight
I also ran 245/45/17 Goodyears with no problems...at all!...no rubbing...now running 235/45/17 Falkens
Old May 15, 2004 | 07:12 PM
soundmike's Avatar
Very sound, Mike
245 will be fine, like you i'm running 235's on an 8" wide rim and the rim is sticking out a little beyond the tire... too late to go back now, maybe when my PZero's go bald i can go wider.
Old May 16, 2004 | 12:51 PM
Thanks guys, this has been very helpful. What about performance issue? Has any one ever experienced sluggishness from wider, bigger tires, therefore heavier, more rotational mass. Any thought on that? My first though would be for the car to be a bit slower off the launch.
Old May 16, 2004 | 12:58 PM
soundmike's Avatar
Very sound, Mike
It's hard to say, i had 18" with Sumitomo HTR+ 225/50 prior to this. Now with 17" (lighter) and 235/45 PZero's, the car actually feels peppier in stop/go driving.
Old May 16, 2004 | 02:41 PM
brianw's Avatar
Hmm, maybe my plan to run 245/50/16's isn't quite so crazy...
Old May 17, 2004 | 08:05 AM
nupe500's Avatar
Jedi Knight
as with getting more contact area...it should handle a bit better.
Old May 28, 2004 | 10:48 PM
BTW I called Pirrelli and found out the Pirelli PZero Nero M + S that I have right now in 235/45/17 weigh 26lbs. 245/45/17 - 28lbs. I didn't get a chance to call Dunlop to ask about the weight of the SP5000 I had before, just to compare them.
Maybe we should get a tire weight listing here. Thoughts?
Old May 30, 2004 | 08:46 AM
Seba2K2's Avatar
Thanks guys
I'm running 245/45/17 and had no problams with them. I have them mounted on 17/8" rims. No rubbing at all
Old May 30, 2004 | 06:41 PM
I guess from the psotings here the rubbing wouldn't be an issue but I am concerned about putting on heavier tires. 2lbs per wheel should have some impact on accelerating.
Anybody know of a lighter all season tire. Maybe then I would consider changing my tires.
Old May 31, 2004 | 02:17 PM
uscav8r's Avatar
Sounds like there shouldn't be any rubbing issues on a 4th gen with 245's and springs. Anyone have a 5th gen with 245's and lowering springs?
Seba2k2, you said you had 245's on 8" wheels with a 40mm offset; are you on the stock suspension?
Nupe, looks like you had some Mustang rims. What offset do they have? Why'd you go to the 235's if the 245's didn't rub?
BTW, anyone know the weight of the 5.5th gen factory alloy 17" wheels (GLE or SE)? Any extra weight of bigger tires could be partially offset with lighter wheels.
Thanks for any input anyone may have.
Old Jun 3, 2004 | 08:05 AM
uscav8r's Avatar
Tire Weight for 245/45's
Called Discount Tire Direct today and here are some weights:
Continental ExtremeContact 245/45-18 = 25 lbs
Conti ExtremeContact 245/45-17 = 25 lbs
Falken ZX-512 245/45-17 = 25 lbs
I also went to Bridgestone's website and they were showing 30-33 lbs for these sizes (in various performance ratings). So there can be a wide range of weights even in a similar size/type.
Old Jun 3, 2004 | 03:59 PM
uscav8r's Avatar
Ya know you don't have to call to get tire weights! Just go to the manufacturers web site, and you can compare weight of all the different models and sizes.
Some have them (Bridgestone, Toyo), most do not (Falken, Conti, Goodyear, Michelin, etc.)....
Old Jun 11, 2004 | 11:51 AM
Vyrus's Avatar
How do you like your P-Zero Nero M+S tires? I want them so badly (in 235/45-17), but they're sold out until late July. Not sure if I'm willing to wait that long!
-Cyrus
Old Jun 22, 2004 | 02:16 PM
2k2nyc's Avatar
I'm on 245/45/18, +45offset, no rub
Fbana41
Aug 29, 2016 12:18 PM
Bonka
Sep 14, 2015 11:18 PM
