18x9 will they fit
18x9 will they fit
thinking about getting 18 x 9 inch rims can they fit or should i go 18 x 8 how much rubbing and if there is what do i have to do to not rub also not have the front rims wider then the fender do to suspension i am getting jic lowering kit also how do i make the rear rims wide enough to be flush with front without loosing the ability to speed and take sharp turns thanx
Originally Posted by slammed95
oK me so sorrry
think get you should 18x9 put max on your fitment fine will be wider fender front rims than fender rims rear rubbing sharp turning jic lowering very good sharp turns speed high good ok
i helps hope this
i helps hope this
WTF??
Let's see if I can solve this puzzle.
I think you should get 18x9. Fitment on the front will be fine. Rear rims rub against the fender during sharp turning. JIC lowering is very good because no rubbing during sharp turning.
~limsandy
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
