will these fit on my 4th gen?
Old Jun 12, 2004 | 07:33 AM
{-_-}'s Avatar
i'm looking at a fs thread and the only thing this guy posted was a picture. they are 18 inch rims. anyone here ever saw these rims?
Old Jun 13, 2004 | 03:51 PM
tpduke112's Avatar
Ive never seen them, if you know that size of the tires, and the offset, i can tell u if they will fit.
Old Jun 13, 2004 | 05:16 PM
mikeI302k's Avatar
they look like they were abused though see the big hole the rim might have been damaged as well when thnat happen. but if they are b/w 38mm-45 mm offset they should fit.
Old Jun 14, 2004 | 11:12 PM
{-_-}'s Avatar
thanks for the answers guys... but i am going to pass on those rims because of that busted tire, i'm guessing that rim is probably damaged in some way. also, i went looking around on tirerack.com and tires.com and this rim is nowhere to be found, so i'm guessing it's some cheap knockoff as well.
i did see some 20x8.5 rims (from a g35), but am under the impression that they might not fit my car as they come with 245/35-20. is that a bit too tight? the correct size should be 235/30-20s, right?
MAXSE5SPD
Sep 17, 2022 04:00 AM
I<3 A32's
Sep 10, 2015 11:07 AM
mclasser
Sep 6, 2015 09:05 AM
Lowered_a33
Sep 1, 2015 07:49 PM
