will acura tl rims fit?
Old Jul 5, 2004 | 10:19 PM
fsr20det's Avatar
i got a good deal ($40 a rim without tires) on three some what curbed up 2004 acura tl rims. a seller on ebay whos selling a set says the rims are 5x114.3, 17x8, +45 offset. i am pretty sure they will fit but i am a maxima noob (sentra/sr20 pro, though) and thought i might as well ask the experts. let me know, thanks guys.
Old Jul 6, 2004 | 03:29 AM
tke148's Avatar
By those numbers they should fit. Stock 2002 SE rims are the same except 17x7. Should be with no problems.
When you get them on post pics.
Old Jul 6, 2004 | 04:00 AM
I30tMikeD's Avatar
It will fit....I would perfer a tad lower offset, but they will fit and look just fine. That is if you don't mind have honda wheels on a Nissan.
Old Jul 6, 2004 | 12:49 PM
Brudaddy's Avatar
Are they the type-S wheels?
Those are sweet, if you could get a center cap that does not say Acura.
Old Jul 7, 2004 | 04:01 AM
SEmy2K2go's Avatar
Go BUCKS!!!
The acura bolt pattern is the same as Nissan's, so they should fit no problem.
Old Jul 7, 2004 | 01:07 PM
fsr20det's Avatar
i know, i know honda wheels on a max.......but $40 dollars, c'mon...i'm not going to run the center cap
and they are 2004 tl rims, i don't think there is a type-s for 2004 yet.
Old Jul 21, 2004 | 03:02 PM
WHOS UR DADDY's Avatar
I think the centerbore is too small on those rims and it might not fit the bore on the maxima. I would look into that if i were u. The bore on the maxima is 66.7 i think so check the acura one, the dealer will tell u.
Old Jul 21, 2004 | 05:20 PM
philthyphil's Avatar
Check the centerbore....you can get it machined but a some cost
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
