What kind of tires should i get?
Old Jul 12, 2004 | 12:52 PM
95maxcntrljrsy's Avatar
im looking for a set of tires that have really good handling in wet or dry conditions, and are pretty good in the snow- i also dont have a lot of money to spend - maximum of 125 per tire - thanks
Old Jul 12, 2004 | 12:55 PM
Jeff92se's Avatar
I'm needing a caw
www.tirerack.com look at the tire reviews. Tires can do almost everything now but you are asking for quite a bit. If you want decent in the snow, you might have to go to an all season performance. You will still get good wet but you might give up ultimate dry and some noise.
Old Jul 12, 2004 | 12:57 PM
knight71's Avatar
Kumho 716 hp4...They're all-season, cheap and H rated. Don't believe me, check this:
According to Epinions top 10 rated tires:
http://www.epinions.com/auto-Tires-A...w_~top_sellers
Old Jul 12, 2004 | 03:46 PM
bump 1234556778
Old Jul 21, 2004 | 01:23 PM
QuickFast's Avatar
What does it mean to bump?
Old Jul 21, 2004 | 01:25 PM
Jeff92se's Avatar
I'm needing a caw
Moved here. Either do some research on tirerack like I suggested or read the numerous similar posts in this section. I must assume you haven't seen this section.
Old Jul 21, 2004 | 02:19 PM
96max5sp's Avatar
Continental ContiExtremeContact I think is a great tire, they are 111 a tire and 3rd overall on tirerack's Ultra High Performance All Season list. These are the ones I am looking to get.
http://www.tirerack.com/tires/survey...jsp?type=UHPAS
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
magiconthetire
Oct 26, 2015 09:03 PM
Garrettz459
Sep 28, 2015 02:50 PM
