235/45/17s
Old Jul 26, 2004 | 09:20 AM
imported_JIC_A33
235/45/17s
will these fit on stock 5.5 gen rims? they are 17*7
Old Jul 26, 2004 | 11:42 PM
E55AMG2's Avatar
Wat
No, they will not. Reason being is that they need a minimum rim width of 7.5 inches to fit properly. The only 235 that I am aware of that fits properly is a 235/50/17. now, with that said, you must take into account the error that a diff tire size creates. the 235/50 makes a 1.5% error (the speedo reads that much lower because the tires are that much taller).
If you read the FAQ in the 5th gen forum, there is a whole thread about this in there.
Old Jul 27, 2004 | 07:02 AM
imported_JIC_A33
didnt someone put a 245/45/17 on a STOCK 5th gen wheel?
Old Jul 27, 2004 | 09:17 AM
E55AMG2's Avatar
Wat
Possibly, but I know that this tire size would rub during U-turns and other extreme steering maneuvers.
Old Jul 27, 2004 | 12:34 PM
erty67's Avatar
Decal Specialist
they will fit, but it is not suggested. if you want 45 tires, i'd go w/ 225/45/17.
Old Jul 27, 2004 | 01:32 PM
imported_JIC_A33
yeah, i have read lots of the pros and cons. i ordered 235/45/17 Toyo 4s.
Old Jul 27, 2004 | 04:50 PM
pigburger's Avatar
Anyone try running 245/50/17s? they're supposed to fit the 7" inch, but I wasn't sure on the clearance.
Old Jul 27, 2004 | 05:21 PM
E55AMG2's Avatar
Wat
if you look a few posts before, we discussed this. T
SR20: The 235/45s DO NOT work on a 7" wheel. Id call back and change it to 225/45 if you are so eager to have a 45 series tire. Also, look for some inflated speedo #s and odo readings
Old Jul 27, 2004 | 07:28 PM
pigburger's Avatar
I understand it was answered about the 245/45/17 but is this anecodotal or theoretical. the 245/45/17 requires a 7.5 inch rim, while the 245/50/17 only requires a 7 inch rim, I was wondering if that made a difference when it came to contact with the wheel well.
Frankly my car turns like a boat, which makes me ask if anyone has experience with the 245/50 and whether it rubs or not.
Old Jul 27, 2004 | 07:43 PM
E55AMG2's Avatar
Wat
The reason the 50 series tire can fit a 7" rim is that the tire has a taller, more flexible sidewall. The widest tire the wheel well can fit is a 245. It will rub only at extreme lock or over big bumps. Id stick with a 235/50. Its more than enough tire (trust me) and you wont miss the extra cm of tire width.
Old Jul 28, 2004 | 04:47 AM
pigburger's Avatar
I would go 235/50 but I'm having a hard time finding an high performance, all season tire that isn't $200. I was just hoping I had another alternative. Thanks for the info though.
Old Jul 28, 2004 | 06:45 PM
imported_JIC_A33
i am all set with my 235/45
thx guys
jayc5627
May 1, 2002 10:59 AM
maximawanabee
Mar 25, 2002 01:13 PM
Lkldraw
Jan 19, 2002 11:28 PM
Versace
Nov 18, 2001 06:00 PM
