Nitrogen filled tires?
Old Aug 23, 2004 | 10:19 AM
Yakuza70's Avatar
I was at Costco yesterday and saw that they offer Nitrogen instead of plain air for their tires. What are the advantages of nitrogen instead of air? The only thing I can think of is that nitrogen won't expand when heated as much as air, reducing tire pressure variance?
Old Aug 23, 2004 | 10:24 AM
mzmtg's Avatar
Minister of Silly Walks
Race cars use nitrogen as well. The main reason is that atmospheric air has many impurities in it, from water to soot. At very, very high speeds, these impurities can affect the balance of the wheel. Using pure nitorgen elminates these impurities.
I can't imagine why you would bother with this ona street car.
As them why they offer it....
Old Aug 26, 2004 | 03:49 AM
vqman
well, air is 70% nitrogen..I guess the other 30% (mostly oxygen) has a bunch of impurities..
-vq
Old Aug 26, 2004 | 05:30 AM
BEJAY1's Avatar
Conecarver
Thanks for the post. That's really odd they'd offer N as an option. I've got a friend who tracks his G35 and filled with N. Keeps the tires from expanding that exctra 3-5lbs under severe heat. Mine fronts expand about 2-4lbs during autox.
Old Aug 27, 2004 | 09:43 AM
MattBeaty's Avatar
In addition to not expanding, nitrogen does not have the impurities in it that attack alloy rims, and cause them to become pitted. There was just an articel by Jay Leno in Popular Mechanics about this. Ingersol Rand now makes a Nitrogen "Air Compressor", just for this purpose.
Old Aug 27, 2004 | 07:08 PM
VQuick's Avatar
Chassis Freak
I always wondered why people don't fill their tires with helium. The decrease in rotational mass would be significant. Or would they weigh the same and my physics is way off?
Old Aug 27, 2004 | 09:28 PM
Matt93SE's Avatar
STFU n00b!
Umm, at these temps and pressures, air and nitrogen will both behave at near-ideal conditions. that means when you get to the track, your air pressure will rise almost exactly the same wether you're running air (72% nitrogen, 16% oxygen, remainder oddball stuff).
The key thing with this is that the tires have DRY air in them. standard air compressors cause a TON of moisture to condense in the lines, and even a huge dryer at the compressor will still not filter out all of the water. The combination of oxygen and moisture in the air is what causes the pitting and corrosion inside the wheel...
from what I have heard talking to race techs, the race tires are filled with nitrogen simply because it's safer- there's no oxygen under pressure inside the tire to fuel a fire in the case a car wrecks and catches fire- then the tire explodes. if it's full of nitrogen and blows, it doesn't fuel the fire.
Old Aug 27, 2004 | 09:43 PM
Matt93SE's Avatar
STFU n00b!
on the helium thing.. it will only make a few grams of difference....
a 235/45/17 tire only has (roughly) 11 liters of air volume in it... at 35psi that's *roughly* 1 mole of gas.
with air at ~30g/mol and helium gas at 4g/mol, you can in theory save about 26 grams per corner.. 26g is just a hair under 1oz... one ounce is nothing. the weight of a pencil. per corner on the car. it's just not worth the hassle. you can rotate the tire on the wheel and save 1oz in weights when you balance the tire.
Old Aug 28, 2004 | 10:56 AM
VQuick's Avatar
Chassis Freak
Thanks for the info, Matt. Good to know.
Old Aug 29, 2004 | 07:11 PM
mzmtg's Avatar
Old Aug 30, 2004 | 06:11 PM
VQuick's Avatar
Chassis Freak
Originally Posted by mzmtg
Well, my reasoning was based on my experience with mountain bike tires: they seem to weigh a lot more at 50 psi than empty. But it is still air we're talking about here, haha.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
ef9
Oct 4, 2015 08:43 AM
Garrettz459
Sep 28, 2015 02:50 PM
