Tire Size for 19x8 (45mm)
Old Aug 29, 2004 | 07:47 AM
ZeRo MaX's Avatar
19x8 rims with a 45 mm offset should have a 245/35/19 tires?
am i correct? or will i rub?
Thanx!
Old Aug 29, 2004 | 10:48 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
might want to try the tires/wheels forum
Old Aug 29, 2004 | 04:18 PM
ZeRo MaX's Avatar
no answer there.. so i tired here :-)
Old Aug 29, 2004 | 05:14 PM
Big_Ham's Avatar
MaximaFreak
Originally Posted by ZeRo MaX
19x8 rims with a 45 mm offset should have a 245/235/19 tires?
Thanx!
I assume you mean 245/35/19 and not 245/235/19 ... in that case:
Prob not. If you did rub, it would rub on the suspension and not the wheel well lip. In this case, 5mm spacers would bump you out enough to avoid suspension rub, but then you may have to roll fenders.
In short, this is an educated guess as I do not have any first hand experience, but there's an art to rim/tire combinations considering the offset. +45 offset will be pushed in toward the suspension, lower offsets will push your wheelbase out more.
Old Aug 30, 2004 | 05:27 AM
ZeRo MaX's Avatar
Yeah that's what i meant, sorry. So it should be fine to have these on my car?
Or would it be better to go with 235/35/19...
Do i need to do any other modifications to put 19's on my ride?
thanx!
Old Aug 30, 2004 | 09:02 AM
Maxillimus's Avatar
235/35/19
Best Choice
Old Aug 30, 2004 | 09:23 AM
MAXRB8's Avatar
Originally Posted by Maxillimus
235/35/19
Best Choice
He's right according to Tire Rack suggested stock replacement 235/35/19 this size with the proper off set shouldn't give you any problems, good luck
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
