Bent Wheel -- Average Replacement Cost??
Old Sep 21, 2004 | 03:19 PM
jones097's Avatar
I have a bent wheel on the front left of my 2001 Maxima SE. Does anyone have an idea of how much it will cost to have this fixed at a Nissan dealership? Any estimate would be helpful.
I took it this morning to MIDAS to have the alignment looked at (my steering wheel is tilted to the left when I'm moving straight), and they said the alignment wasn't the problem -- it was a bent wheel. Is there a correlation there, or do I need a new wheel AND a new alignment? Please let me know.
Thanks all.
Old Sep 22, 2004 | 06:18 PM
z32drifter's Avatar
If your wheel is bent.... the dealer can't fix it..... they could send it out to a wheel repair co.... dealer will reccomend new wheel..... if your steering wheel is off center.. I would be suprised if the alignment is not off.....you could even have a bent suspension part.... If it were me I would find a nice used wheel to replace the bent on and have the car realigned... make sure to tell the tech that the steering wheel is off center.. they can correct that during the alignment..
Old Sep 23, 2004 | 07:59 AM
Triple8Sol's Avatar
I miss the .org!
If you can locate a local shop to fix them, it will probably run you around $90-150 depending on how badly bent, if there's curb rash, and if they have to refinish any part of it...
Old Sep 23, 2004 | 06:50 PM
Ammi's Avatar
350 Detroit Muscle
It will be cheaper to buy 1 wheel from ebay or something. I was quoted 100-250 depending on how bad the rim was bent.
Old Sep 23, 2004 | 07:21 PM
kklier's Avatar
I bent mine. Cost me $125 to have it fixed here:
http://www.wheelexchange.com/
its a b!tch to balance, but it does balance.
Old Sep 24, 2004 | 07:05 AM
desperado_45's Avatar
It would be cheaper to buy 4 aftermarket rims than one new nissan rim. So check junkyards.
Old Sep 24, 2004 | 07:24 AM
spirilis's Avatar
1 new Nissan rim is over $500 at the dealer AFAIK. I bought a set of 4 wheels off eBay for ~$440 shipped. I had 1 wheel replaced about 6 months before and it cost me $336 total, and it was a used wheel (the dude was probably ripping me off a little, come to think of it... but I really wanted to get rid of that horrible shimmy so I went with it)
homeyclaus
Sep 3, 2015 06:15 PM
maxipower
Aug 21, 2015 11:10 AM
Samedi
Aug 12, 2015 01:54 AM
kirkhilles
Aug 8, 2015 10:53 AM
