Need help with tire balancing..!
Old Sep 27, 2004 | 08:42 PM
Grey00lustre's Avatar
i don't know if this is a good question or not but my question is recently i put on a set of 17' aftermarket rims and it's been giving me vibration on the steering wheel everytime i go above 60mph....now i had the tires balanced and it didn't solve the problem..i was wondering if i get a alignment would that help or fix the problem?
Old Sep 27, 2004 | 08:45 PM
Ant96GLE's Avatar
It should definately help the problem.. however if you have a bent control arm or tie rod, it'll keep doing the same thing.
Old Sep 27, 2004 | 08:54 PM
my car has no bent control arm or anything....
Old Sep 27, 2004 | 09:19 PM
DAVE Sz's Avatar
Hooooooonda.....
Do you need an allignment after getting bigger rims?
Old Sep 29, 2004 | 10:56 AM
passEMonTHErite's Avatar
A lot of tire places *cough* NTB *cough* don't know **** from shiola when it comes to balancing tires. Been there done that. There could also be a broken belt in the tire they dont want to admit to because that would mean they would have to reimburse you (depends on the wear of the tire) at a prorated amount. Go back to where you got it balanced, have them do it again, when they give it back to you, take it out to the highway, if there is still vibration, turn it around and go right back. Repeat until they get it right.
Old Sep 29, 2004 | 12:04 PM
mzmtg's Avatar
Minister of Silly Walks
www.gsp9700.com
Old Sep 29, 2004 | 02:30 PM
Galo's Avatar
Maxima Pilot
Originally Posted by mzmtg
I echo that, u may need a RoadForce Analysis.
But, before u spend the 80 to 100 bucks you'll pay for a Road Force analysis, make sure your aftermarket rings are properly 'hub centric' or if they are not, that they were supplied with hub centric rings.....
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
