who sells hubcentric rings - i need 76.02 mm wheel center bore
Old Oct 4, 2004 | 06:22 AM
nick's Avatar
any of you guys know about vendors that sell rings in 66.01 inner and 76.02 outer diameter?
I need them asap. Discont tire direct don't have them
thanks
Nick.
Old Oct 4, 2004 | 07:20 AM
kwd2kSE's Avatar
And I thought those guys had every size made, oh well. I would try going directly to the wheel manufacturer for the wheels you have. The inner rings should be 66.10 - per the two sets sitting on my desk right now.
Mike
Old Oct 4, 2004 | 07:49 AM
nick's Avatar
see the problem i have - the prior owner of wheels i have now ( TSW Revo ) had the center bore of those rims machined out to 76.02mm , and i'm having hell of the time in finding rings in that size. Plus i want the metal ones , not plastic.
yes - the inner diameter of maxima center bore is 66.01mm.
i need ring with outside diameter of 76.02 mm
Nick.
Old Oct 4, 2004 | 02:42 PM
Mizeree_X's Avatar
Getting back to his roots
Nick.
I would think having a machine shop make a set might be your easiest bet. Shouldn't cost too much either.
Old Oct 4, 2004 | 02:44 PM
Jeff92se's Avatar
I'm needing a caw
What kind of car had the 76.02mm hub bore? Mustang?
Old Oct 4, 2004 | 02:47 PM
Jeff92se's Avatar
I'm needing a caw
Closest I could get
http://www.prestigewheel.com/HubRings.asp
Old Oct 4, 2004 | 04:19 PM
nick's Avatar
Thanks, I've made some phone calls locally and i will have those custom made.
I really don't know for what vehicle was those rims machined out to 76.02mm
Nick.
morteljc
Wheels/Tires
Oct 22, 2015 08:43 PM
TheMafia
Sep 4, 2015 08:26 AM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
