Does a 18x8 with 33+ offset fit ok on 5gen?
Old Oct 8, 2004 | 09:47 PM
Grey00lustre's Avatar
i'm looking into picking up a set of new wheels and was wondering if these spec fit my 00 max or not...
Old Oct 9, 2004 | 07:56 AM
any help would be appreciated..
Old Oct 9, 2004 | 09:17 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
I know 18x8 with +35mm will fit, and I'm not sure if the extra 2mm+ offset will make much of a difference...
Old Oct 9, 2004 | 09:42 AM
scopium
it wont fit
Old Oct 9, 2004 | 10:54 AM
Lumbee1's Avatar
It will fit just fine. I am running 18x8 with 30mm offset.
Old Oct 9, 2004 | 03:24 PM
thanks for the help you guys...
Old Oct 9, 2004 | 03:33 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
fit with no problem. If you lower the car quite a bit you might have some rubbing issues.
Old Oct 9, 2004 | 07:53 PM
Triple8Sol's Avatar
I miss the .org!
To reiterate, 30 is fine. You could even go w/a lower offset than that if you want.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
