19x8.5 mm evo5 what size tire
Old Oct 16, 2004 | 06:56 PM
Qmax03
im getting these evo5's ..... 19x8.5.... should the tire be 235, 245, 255 ?
Old Oct 16, 2004 | 07:02 PM
dblrr900's Avatar
245 def. a 40 series if you want to keep the rims together with those NY streets. usually they will try to push a 35 series on you, but I wouldnt go with that.
Old Oct 17, 2004 | 08:52 AM
Qmax03
thanks alot bdlrr, i know i should get a 40 series but jsut wondering about 235 or 245, so i guess im getting 245/40/19 , continentals
Old Oct 17, 2004 | 05:23 PM
Nemmeh's Avatar
make sure you definitely get a 245/35/19 at the least... I just got a set of 19x8.5 with 245/35/19's and I'm glad I did.. If I wouldn't have, the tires would have been way too stretched onto the rim.
I went with a set of (4) Falken Azenis ST115..
A 40 series tire should be fine.. I probably could have went with the 40, but instead I did the 35 series.
Old Oct 17, 2004 | 08:32 PM
Triple8Sol's Avatar
I miss the .org!
It's just that 40 profile with that size will look really ridiculous. I'm running 235 on a 8.5 right now, but wish I still had my old 245 on an 8.
Old Oct 18, 2004 | 09:45 AM
Triple8Sol's Avatar
I miss the .org!
Yup, 255/35/19 is what I plan for next set if I still have these rims by then
Old Oct 18, 2004 | 01:18 PM
maseo77's Avatar
255 wont rub in the front with maxspeeds would they?
and you say with a 40 series acceleration will suffer but with a 255 it wont?
255 will slim your search results far greater than 245 when searching online.
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
