tires size!
Old Nov 3, 2004 | 04:14 PM
khynex's Avatar
tires size!
You think 235/45/17 will fit in the 02 se rims?
Old Nov 3, 2004 | 05:40 PM
Max_Vader_2K's Avatar
235/45R17: This tire size is NOT in spec on 7.0"-wide rims. (The minimum acceptable rim width for this tire size is 7.5".) It produces a speedometer error of 2.1%, well within the recommended maximum speedometer error of 3.0%. Load ratings for this tire will normally equal or exceed that of the 225/50R17 (load rating 93) and should not be a factor in selecting tires of this size. Watch for abnormal wear characteristics if you select a tire in this size.
This is in the FAQS sticky. take a look
Old Nov 3, 2004 | 09:11 PM
Ammi's Avatar
350 Detroit Muscle
it will fit but stick w/ 225/50/17 tires.
Old Nov 3, 2004 | 10:50 PM
erty67's Avatar
Decal Specialist
Nobody ever reads the MAXFAQS. 215/50/17, or I've heard 225/45/17 "recommended" also
https://maxima.org/faq-6-Tires+and+Wheels.html#45
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
