which size tire?
I am lowered on JIC's. I am currently running a 245/45/18 i need to go smaller. But am confused with whether to go for a 225/45/18 or a 245/40/18 or a 235/40/18. Could someone with some tire knowledge tell me what my best choice here is for ride and how low I could take the car with each. Offset on the rims is 42mm and the rim is 7 or 7.5 inches wide.
235/40/18 would be ideal, 245/40/18 could also work, but might not be smaller enough for you, and also might rub with that offset. |
why did you get 45s to begin with? You can run either 235/40/18 or 245/40/18.
well depending on your rim..... 225/45 for a 7" or the 7.5" rim.... you can run the 235/40 on a 7.5" ... 245/40 should be on a 8" rim
© 2024 MH Sub I, LLC dba Internet Brands
