Will 14 inch rims be a problem?
Old Dec 9, 2004 | 12:07 AM
enticiveblkmax's Avatar
A friend of mine is giving a set of Mitsu Eclipse Steelies (14in.) away and I was thinking about mounting some snow tires on them to use with the Maxima. Will this cause any problems? The bolt pattern is the same but I think the offset may be +45. Any insight is appreciated. Thanks.
Old Dec 10, 2004 | 12:53 PM
SPiG's Avatar
SomePsychoGuy
I doubt they will clear the calipers. I would also check the bolt pattern.
Old Dec 10, 2004 | 12:58 PM
Bman's Avatar
I have the same doubt with the brakes, but maybe do a test fit and report back.
alahjahwan09
18
Sep 21, 2015 09:12 PM
0m3nc0w
Sep 11, 2015 05:21 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
Maxboy23
Sep 4, 2015 06:04 PM
