Wheels / tires question
Old Dec 13, 2004 | 04:48 PM
pearlywhite2k's Avatar
So I just got some 18"s for my Max. I know what tires are recommended, but I can get a real good deal if I go one size up (and I think may be more comfortable on the road) Most people are running 235/40's or 225/45's, I just wanna run 235/45. So just wondering if this is a bad idea or I will have rubbing problems. Im also gona probably end up running the Tein-s springs.
thanks
Old Dec 17, 2004 | 04:28 PM
swiss_alps's Avatar
reply
That may not work. You should compare the overall tire dimensions, especially diameter, of your car's stock tire and that of the tire you 'desire.'
I often use a tire size calculator on www.1010tires.com
They warn not to go more than 3% different in size from your stock... I am sure in many cases that is a reasonable range.
Also, tire companies usually give the tire specs on their homepages.
Garrettz459
Aug 29, 2015 02:18 PM
cheftoo
Aug 24, 2015 09:20 AM
gizzsdad
Aug 19, 2015 01:01 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
