Will this offset work?
Old Dec 25, 2004 | 01:40 PM
fadeaway's Avatar
Go Hokies!!
Hey everyone,
Will 45mm offset work for a 4th gen? I could get a great deal on a set of rims I want, but they are 45 offset. I heard the only way to deal with this is to get "spacers", but I also heard it isn't a good idea to use them..
Thanks.
Dan
Old Dec 26, 2004 | 09:00 AM
Ammi's Avatar
350 Detroit Muscle
You can use 5mm spacers w/ OEM studs but if you get wider spacers, definitely get longer studs.
Old Dec 29, 2004 | 11:04 AM
I30tMikeD's Avatar
45 offset is fine, but the rims just won't be as flush as the could be. Now if they are 8" wide then 45mm offset would not look too bad, but if they are 7" or 7.5" you might be kind disapointed. For a 7" or 7.5" rims look for a 35mm offset, or even a 40m.
Old Dec 31, 2004 | 07:27 AM
fadeaway's Avatar
Go Hokies!!
Thanks. Will they just look a little too squished into the car? I'll probably just go to a tire store and see what they think/recommend when I get my wheels.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Hailstatejig
Sep 2, 2015 06:52 AM
umnitza
Sep 1, 2015 01:03 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
