Question about wheel spacers and 2k SE Rims
Old Jan 5, 2005 | 08:19 PM
Magikone69's Avatar
hi guys
i have a 4th gen and jus got some 2k SE 17 inch rims put on my car. i love the way the rims look on the car, esp the front because they are lined up perfect with the fender. looks very sporty.
the rear on the other hand is a different story, they look so sunken in, like they were pushed in on purpose. my thought is to buy a set of spacers for the rear but im not sure what size. im lookin around and i see some as large as 1 and 3/4 inch and that seems too much. i also see some at 5mm but that seems too small. i just wanted to know what size would bring the rear wheels to the edge of the fender without over extending.
also im curious as to how do i install them, do i jus take the wheels off and slide em on?, do i have to extend the bolts? are they safe?
and are the ebay ones a good buy, i see em on there for 20-30 bux, are those good. i also see some as high as 300 bux, if they are that much then ill just say forget it to te whole idea.
here is link to one of the "ebay brand" spacers, not nec the size i plan to get.
Click here
Old Jan 5, 2005 | 10:11 PM
Ammi's Avatar
350 Detroit Muscle
You can probably use 15mm spacers but you will need longer studs. Look for H&R spacers with built in studs.
Old Jan 6, 2005 | 02:16 PM
Magikone69's Avatar
i found the h&r spacers, i think im gona go with them since they have built in studs. thanx ammi.
so 15mm is a good size to bring the rear wheels even w/ the fender
Old Jan 6, 2005 | 05:04 PM
Ammi's Avatar
350 Detroit Muscle
This is w 20mm spacers on a 5th gen
Maxima_Joe
Nov 25, 2015 08:19 AM
incubusjohnny
Nov 3, 2015 05:18 PM
