19x7.5 +44 offset?
Old Jan 9, 2005 | 02:03 PM
xtantmaxima's Avatar
19x7.5 +44 offset?
it shows the clearance to the strut will be 5mm less, is this ok? I found a deal for Racing Hart S15 in this size.
Old Jan 9, 2005 | 03:51 PM
maxspeed96CT's Avatar
The original VQ...
no way, you need a rim at least 8" wide, 7.5 is to skinny and it will look stupid, and a 44 offset will requre the use of spacers because the wheel will be to far in.
Just wait or find something else.
Old Jan 9, 2005 | 04:40 PM
Ammi's Avatar
350 Detroit Muscle
Don't even spend money to get 19s if they are only 7.5" wide.
Old Jan 9, 2005 | 09:11 PM
ok, what offset for a 5th gen with 19x8 or 19x8.5. I found another nice set of wheels with either of these dimensions. the 19x8.5 has a 38mm offset which shows a 12mm less strut clearance and 26mm further than before. Will this cause a problem? I have also seen 19x8 with the same offset which would make the wheel 6mm closer to the strut and 20mm further out. What will be the best?
Old Jan 9, 2005 | 09:14 PM
VIP Maxima
19x7.5 = trash
get some REAL "VEHICLE" rims not a bike wheel
Old Jan 9, 2005 | 09:20 PM
Ammi's Avatar
350 Detroit Muscle
Go w/ the 19x8.5 w/ 38mm offset. I know someone who's running 19x8.5 w/ 35mm offset without issues.
Old Jan 9, 2005 | 09:35 PM
SEmy2K2go's Avatar
Go BUCKS!!!
18" & 19" wheels MUST be 8" wide. End of discussion.
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
