to the wheel gurus
Old Jan 10, 2005 | 12:44 PM
iRaMarine's Avatar
to the wheel gurus
I found a set "like new" condition, 6 spoke, 17" rims off of a G35 (sedan).
I am fairly confident, but I want to ensure that these will bolt on without the need for any type of spacers; and I need to know what size tires I will have to buy. The rims are 17x7 with a 40mm offset and a 5 lug, 4.5" pattern.
TIA
Old Jan 10, 2005 | 01:41 PM
thephatOne's Avatar
7 inch will be 215/40/17 thats what i would run, and no you wouldnt need a spacer because i believe the rim is 114.3x5 and 40mm is fine, i run 40mm also with no problem
Old Jan 11, 2005 | 05:22 AM
Pizatt's Avatar
yeah they will work....
Old Jan 11, 2005 | 07:27 AM
iRaMarine's Avatar
kewl. thanks.
Old Jun 3, 2005 | 01:39 PM
flewdawg's Avatar
01 I30 .. aka White Diamond
I've been wondering the same thing about those G35 rims............I want a set of chrome ones
Old Jun 6, 2005 | 11:00 AM
i30ds's Avatar
Armed and Dangerous
No that is the wrong size to run. A 215/40 is way to small of a tire for a 17x7 rim. According to tirerack.com, the correct size is 235/45. That is what I have on my 17x7s with 42mm offset and they are perfect as they did not throw my speedometer or odometer off.
Old Jun 23, 2005 | 12:28 AM
HowLeTT's Avatar
how about a set of 18's off a g35 coupe? i'd like to run them with 225/45/18 tires on there. will these have any problems with rubbing on an 03 i35? thanks!
Old Jul 4, 2005 | 10:24 PM
SuperWario's Avatar
sweet stuff man
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
Redfox
Sep 28, 2015 10:41 AM
