need a little help on rims if possible
hey guys..i'm actually planning on getting new rims and i was wondering if there is a way to get nice 18's without lowering your car..i cant really afford that right now..i have my stock non alloy hubcap wheels on right now and they are 205/65R15 and i want to get 225/40/18..do you think this will look okay without a drop since the profile is so much lower? or will it still make it too high? any comments/suggestions would be awesome
thanks
thanks
The car will not be lifted, but the wheel gap will be more pronounced since you are going to have low profile tires. You don't have to lower your car but it will look a lot better if you did so.
Many here will tell you to do your suspension first, then save up again and do the wheels since the suspension actually has performance bebefits ie. better handling and ride comfort.
Since you have 15" wheels, you could get some 17" wheels which is the stock size on the 5.5 gen which would look fine without lowering your car. Also, a 2" increase in wheel size will be quite noticeable. Just a suggestion.
Edit: Are you sure yours are 15" ?
yea i understand..but i want 18's because i want darker rims with a light lip and those usually look smaller than they really are..so i thought about 18's but if they will look out of place without a drop then ill consider 17's
0m3nc0w
Sep 11, 2015 05:21 PM
