Help With Rims
Old Jan 11, 2005 | 08:51 PM
jatt806's Avatar
Help With Rims
Hi guys - can someone tell me if the following rims would fit my 01 Max SE
PATTERN IS 5-114 AND THE SIZE IS 18X8.
I really appreciate your help.
Old Jan 11, 2005 | 08:57 PM
WildmanAL's Avatar
All you have to do is do a tiny bit of searching or maybe even a phone call to the dealer you're buying them from and you'll beable to find out that yes they do fit.
Old Jan 11, 2005 | 09:19 PM
mistermax's Avatar
yes they will fit. 5X114.3 to be exact would be the bolt pattern u are looking for.
Old Jan 11, 2005 | 09:20 PM
jatt806's Avatar
Thanks for the response, but these are from a private sale and the guy has no idea if they will fit or not. So I figured someone on here would be nice enough to help me out. If there is a place you know of where I can search, please let me know.
Old Jan 11, 2005 | 11:20 PM
limsandy's Avatar
All of the above information is not enough to determine if the wheels are going to fit your car or not. You need to know the offset of those wheels.
~limsandy
Old Jan 11, 2005 | 11:28 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Are they aftermarket wheels? For detailed answers, we do need a bit more information.
Old Jan 12, 2005 | 05:57 AM
max5spd's Avatar
Says.."No mo Maximas for me!"
what's the offset?
Old Jan 13, 2005 | 11:07 AM
MAXecutive's Avatar
The offset will determine how the far in the wheel will sit. If it will stick out or not. The right offset is needed because aftermarket wheels come in different offsets. The bolt pattern only means that it will be able to bolt on; if the offset is too high or too low, it will not fit the vehicle correctly. Check out this link on offsets.
http://www.discounttiredirect.com/di...eelOffsets.jsp
Old Jan 13, 2005 | 08:38 PM
Triple8Sol's Avatar
I miss the .org!
Jesus Christ. Try reading a couple threads in this forum. Nobody else reply...waste of space...
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
