Rims Question
Old Jan 17, 2005 | 05:15 AM
Kramit_N_Die's Avatar
Rims Question
Has anyone placed a set of +42 offset rims on thier 95-99?... I have the opportunity to pick up a nice set of 17x8.5 Enkei V1 rims with a +42 offset and was wonderign how bad they may "scrape"....
Old Jan 17, 2005 | 08:44 AM
BRAN808's Avatar
There's a couple of factors. Depending on how low you're dropped and what tire size you're going to be running. But I think with that offset, and none of the above 2 are out of whack, you'll be Okay!
Old Jan 17, 2005 | 08:54 AM
I am on a set of aerospeed lowering springs and factory struts = 2" drop... But I am about to purchase the Tokico HP series struts and springs...
Old Jan 23, 2005 | 05:07 PM
I was wrong about the offset. They are Enkei V1 rims 8 1/2" wide with a +29 offset... Will they fit?
Old Jan 24, 2005 | 11:33 AM
Triple8Sol's Avatar
I miss the .org!
You'll be fine depending on tire size.
Old Jan 24, 2005 | 11:42 AM
I was thinking about going with 235/45-17 Kuhmo ECSTA ASX Tires....
Old Jan 25, 2005 | 07:09 AM
Please help... I am going to buy them this weekend...
Old Jan 25, 2005 | 09:47 AM
Triple8Sol's Avatar
I miss the .org!
Doubt you're slammed enough to have to really worry about rubbing
Old Feb 2, 2005 | 06:57 AM
Anyone know the factory offset for the 95 SE "blades"... and what is teh stock rim width?
Old Feb 2, 2005 | 03:07 PM
Stuntin' 101's Avatar
i have a set of 18x8.5 enkie v1's if your intrested... one has slight curb rash, with a slight bend in it, and i think another might have a minor bend in it.. wrapped in toyo proxies.. but at any rate, i think they were a 35 offset, with 245/40/18's.. i can check if it will help you. and they didnt rub on my car, im lowered with h&r's
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
Serotta33
Sep 17, 2015 12:14 PM
0m3nc0w
Sep 11, 2015 05:21 PM
adamgalazka
Sep 8, 2015 01:27 PM
