rim size
Old Jan 28, 2005 | 06:41 AM
2kprlmax's Avatar
rim size
Would this fit on a 2kmax:
18x8.5/offset 30sh/bolt pattern 5X114.3
Old Jan 28, 2005 | 06:56 AM
mzmtg's Avatar
Minister of Silly Walks
Yes. It will fit.
Old Jan 28, 2005 | 07:05 AM
2kprlmax's Avatar
ok I went to the stickie and got this calculations, the first is 8 width 50 offset, the second is 8.5 width 30 offset:
http://toy4two.home.mindspring.com/offset.html
My question is which one will be closer to stock?
Almost forgot will the bolt pattern of 5x114.3 fit eventho we are 5x114
Old Jan 28, 2005 | 09:14 AM
2kprlmax's Avatar
Sorry about the links
Here is what it says with 8 width 50 offset:
The clearance from stut housing to the inside of the wheel will be 18mm LESS
The outside edge of the wheel will EXTEND an extra 8mm
Here is 8.5 width with 30 offset:
The clearance from stut housing to the inside of the wheel will be 2mm MORE
The outside edge of the wheel will EXTEND an extra 28mm
Which would look more closer to stock, I am guessing the 8width and 50 offset
Old Jan 28, 2005 | 09:34 AM
Triple8Sol's Avatar
I miss the .org!
I'd suggest 30 offset...it will look waaaay better. 50 offset will look really silly.
Old Jan 28, 2005 | 11:24 AM
2kprlmax's Avatar
so with the 50 it will stick out of the fender, correct. Now what if I am going to lower the car should I get the 30 or the 50 is ok
Old Jan 28, 2005 | 01:22 PM
Ammi's Avatar
350 Detroit Muscle
50s will be tucked in more than 30s. I would get 35mm offset.
Old Jan 28, 2005 | 08:50 PM
2kprlmax's Avatar
they don't have 35 they only have 50 and 30
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
knight_yyz
Nov 1, 2015 01:34 PM
