how do you measure wheel width???
Old Feb 24, 2005 | 03:22 PM
huyqvu's Avatar
when i had the wheels repaired, they took off the tires and i dont remember the width. so if i were to measure, is the from the outer edge of the lip or inside of the lip?
Old Feb 24, 2005 | 04:50 PM
Ammi's Avatar
350 Detroit Muscle
all it takes is a simple google
Old Feb 25, 2005 | 05:18 AM
huyqvu's Avatar
thanx for the info dude.
Old Feb 25, 2005 | 06:46 AM
max5spd's Avatar
Says.."No mo Maximas for me!"
Usually, the wheel width is stamped on the inside of the wheel.
Old Feb 27, 2005 | 05:50 PM
huyqvu's Avatar
nope its not stamped on these. i measured it and it comes out to 8.75". i called discount tire and some fuktard said 225 would be fine and i wouldnt have to worry about the tire being smaller than the rim. so should i get 235 or 245? what do you guys think?
Old Feb 27, 2005 | 09:40 PM
Ammi's Avatar
350 Detroit Muscle
probably 8.5. Run 245s or 255s
Old Feb 27, 2005 | 10:27 PM
$tillenmax2k
The size and offset is stamped on nearly every single wheel. I've never seen one without that. Look in the back of the hub area, around the bolt pattern.
If they are 8.5's, go with 235 or 245. If they are 8, go with 235.
AaronL
Nov 15, 2020 11:52 AM
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
I<3 A32's
Sep 10, 2015 11:07 AM
