255/40/19
Old Mar 14, 2005 | 03:31 PM
steaLthyMax's Avatar
255/40/19
Will these fit on a 5.5 gen? Debating on whether or not to buy these rims from someone depending on fitment.
Old Mar 14, 2005 | 03:33 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
seems wide as hell...what is the offset of the rims? thatll be your determining factor along with your drop height.
Old Mar 14, 2005 | 03:38 PM
NisMoN00B's Avatar
+Cru OG
i would think 255s would fit the rear if you're going for the staggered wheel option. Might need some spacers for the rear to fit those meats.
Old Mar 14, 2005 | 04:01 PM
yeah initially i thought it was a little wide as well. The rims are 19x8.5 +38 offset. All 4 tires would be the same size so it should stick out about an inch more than stock.
Old Mar 14, 2005 | 04:11 PM
NmexMAX's Avatar
dot dot dot ...
I'd say 245 would be my choice, all around good look and fitment, and the speedo wont be terribly off.
255-35 will match the speedo better if you want to still have the same width.
Old Mar 14, 2005 | 11:17 PM
SEmy2K2go's Avatar
Go BUCKS!!!
245/35/19 here. No rubbing issues at all.
Old Mar 15, 2005 | 01:15 AM
Thanks. What offset are your rims?
Old Mar 15, 2005 | 04:11 AM
SEmy2K2go's Avatar
Go BUCKS!!!
+40mm if I'm not mistaken.
Old Mar 15, 2005 | 05:12 AM
expressinme's Avatar
really damn wide
PetitFrereMaxima
78
Oct 9, 2013 06:41 AM
viper92086
Wheels/Tires
Feb 16, 2012 06:01 PM
MaxedOut99SE
Wheels/Tires
18
Jul 22, 2010 05:13 AM
2000 Maximus
Wheels/Tires
Aug 17, 2007 10:41 AM
