Wheel spacers...
Old Apr 25, 2005 | 09:26 AM
fornimage's Avatar
Wheel spacers...
Has anyone installed wheel spacers on thier 2002 Max with the longer studs? It says on H&R's website that the studs are suppose to be pressed into the existing hub. I'm debating whether I should use spacers to fill that gap in the rear cuz I intend to put stock rims back on for the winter. How will the longer studs affect my stock rims? Thanks!
Old Apr 25, 2005 | 09:47 AM
Mizeree_X's Avatar
Getting back to his roots
If you install the longer studs and ever run wheels without the spacers, you'll most likely need to use open-ended lug nuts. That's about all I can think of. The hub is part of the car, not the rim.
Old Apr 25, 2005 | 07:49 PM
fornimage's Avatar
Thanks for the reply. Anyone else have some peronal experience with wheel spacers?
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
