Rim Spec Question...
Old May 3, 2005 | 10:10 AM
dadiesel's Avatar
What is the correct bolt pattern and offset for 01's? My for bolt pattern choices are 5-100, 5-112, 5-114.3... The first two have 40 offsets and the third has 30. I appreciate any help .
Old May 3, 2005 | 10:30 AM
KCMC582's Avatar
the bolt pattern is 5x114.3, nothing else will fit. i believe either offset will fit, but the 30s will be more toward the outside of the wheel well, possibly just flush with the fender. the 40s will be more inside the wheel well. someone correct me if im wrong. also, check the wheel and tires forum, much better explanations of offset than i am giving.
EDIT: You just got moved there
Old May 3, 2005 | 11:39 AM
CCS2k1Max's Avatar
The OEM rim specs are in the owners manuals, which can be downloaded if you don't have it. SE wheels: 17x7JJ, 5x114.3 mm pattern, +45 mm offset, 66.1 mm center bore. KCMC has the offset idea right, but it does depend on the rim width. The wider the wheel, the less positive offset you should go with (no more than 30-33 mm), otherwise it will rub.
Old May 3, 2005 | 02:39 PM
dadiesel's Avatar
Thanks!!!!
Old May 4, 2005 | 04:48 PM
jason3361's Avatar
I am looking at buying some 18 inch rims for my 98 maxima. I have yet to see them and having a difficult time on the phone trying to get the tire specs (width) the kid is a little shady
will 18 fit my ride? what is the maximum width of rim that i can use so i am not rubbing
anythoughts would be great
jmlee44
Oct 2, 2022 02:13 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Quickywd01
Sep 21, 2016 09:36 PM
Fbana41
Aug 29, 2016 12:18 PM
