Eagle F1 - tires
Eagle F1 - tires
Finally given up on getting a new set of lightweight 18" wheels. Can't find any style I like as much as the OEM 17" on my SE. My question is....for the Goodyear Eagle F1 GS-D3 tires I can now get the size of 235/50/17 or 235/45/17... I was thinking of going with the 50 series instead of 45 to fill the wheel gap out a bit. Think I'm crazy for going with the 235/50/17 instead of the 235/45/17 ?
Peter
Peter
Amen to that
I went from 225/50/17's to 235/45/17's on my 03, I have Pirelli Pzero Nero M/S. Helps that the tire has a fairly stiff sidewall, but if you get ones without you may get some "interesting" handling.
So,
- You like the 17 inch OEM rims
- You don't want to go off spec on the 7 in wide rim
- You want to go with a little wider tire
- You want stiff sidewalls but don't want the 4x4 look
